01-06-2010 04:44 AM - edited 07-03-2021 06:23 PM
Does anyone know why 1250 AP's have to use 802.3at to power both radios but 1142n AP's can use standard 802.3af without comprimise?
01-06-2010 06:05 AM
My understanding is that the 1250s (being modular) have additional PCI circuitry that requires more power. I don't remember where i read that, but it seemed to make sense at the time. -John
01-06-2010 06:49 AM
That is correct, if you look at the older ask the expert sessions, find the one with Fred Niehaus, and he explains why the
1250 requires more power.
01-06-2010 01:25 PM
Hi Mat,
Please don't compare apple with oranges. The 1140 and the 1250 were designed differently (other than looks and weight). Like it's predecessors, the 1250 was designed for wide-open spaces deployment hence the transmission footprint is significantly wider. The 1140 is designed for office space use hence you don't need a very strong transmitter.
If you upgrade the 1250s IOS to 12.4(10b)JDA3 you should be able to power the 1250, with both radios, on 15.4w but at a cost of lower MCS rates.
Hope this helps.
