question on ACS re-image and restore
Jan 6th, 2010
Just wondering as I haven't found this in the docs (yet). Maybe someone
has come across this and might know.
When doing a re-image and restore on an appliance, is the
certificate information retained? I do have notes made on the
config so that in the very worst case, I can re-build by hand. I
do not expect to have to resort to this.
The only thing that I can't re-do is the certificate as I don't have
the key pair file (only the certificate itself). This would be an issue
as the ACSs being upgraded are for wireless and my understanding
is that the cert is needed for PEAP and EAP-TLS.
But if the certificate info is retained as part of backing up the config,
then it should be retained during a restore and everything should work
out just fine. I'll keep digging to see if I can find this documented, but
and advice is appreciated. Thanks - chris
cmarva Wed, 01/06/2010 - 05:26
of course, now I find it. According to the documentation, the certificates and
trust lists are indeed included in the backup. - chris
