01-06-2010 06:09 AM - edited 03-06-2019 09:10 AM
How is this possible? Multiple Switches claiming to be spanning tree root.
The network has 2 cores. Both 6513. 1 is catos 1 is IOS. Spanning tree seems to be messed up with multiple switches claiming to be root for most of the VLANS here. STP is configured only on the cores. Yet the access layer switches seem to claim to be the root? Strange? Is this some bug in CATos?
CORE1:
At the core is an old 6513.
WS-C6513 Software, Version NmpSW: 8.6(4)
System Bootstrap Version: 7.1(1)
System Boot Image File is 'bootflash:cat6000-sup2k8.8-6-4.bin'
Core6513> (enable) show spantree 2
VLAN 4
Spanning tree mode PVST+
Spanning tree type ieee
Spanning tree enabled
Designated Root 00-0b-fc-d3-10-00
Designated Root Priority 4100
Designated Root Cost 0
Designated Root Port 1/0
Root Max Age 20 sec Hello Time 2 sec Forward Delay 15 sec
Bridge ID MAC ADDR 00-0b-fc-d3-10-00
Bridge ID Priority 4100 (bridge priority: 4096, sys ID ext: 4)
Bridge Max Age 20 sec Hello Time 2 sec Forward Delay 15 sec
Topology change initiator 4/9
Last topology change occured Tue Jan 5 2010, 18:22:49
Topology change count 409
Port Vlan Port-State Cost Prio Portfast Channel_id
3/11 4 forwarding 4 32 disabled 0
3/15-16 4 forwarding 3 32 disabled 1737
set spantree priority 4096 1-2,4-20,22-24,26-45,50-53,55,67,80,99-103,105,130,150-154,156,175,222,237,239,265-268,272,290-295,302,310-311,371,666,700,803
Core2:
cisco WS-C6513 (R7000) processor (revision 1.0) with 458720K/65536K bytes of memory.
IOS (tm) s72033_rp Software (s72033_rp-ENTSERVICESK9_WAN-M), Version 12.2(18)SXF, RELEASE SOFTWARE (fc1)
VLAN0004
Spanning tree enabled protocol ieee
Root ID Priority 4100
Address 000b.fcd3.1000
Cost 3
Port 1665 (Port-channel159)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 36868 (priority 36864 sys-id-ext 4)
Address 0014.1b33.1d40
Aging Time 300
spanning-tree vlan 1-2,4-20,22-24,26-4094 priority 36864
Access Switch #1:
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 08-Jun-05 01:19 by yenanh
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEA, RELEASE SOFTWARE (fc)
CISCO3750POE-6thFloor uptime is 43 weeks, 4 days, 7 hours, 9 minutes
System returned to ROM by error - Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!, PC 0x757C7C
System restarted at 06:35:30 UTC Sat Mar 7 2009
System image file is "flash:c3750-ipbase-mz.122-25.SEB2/c3750-ipbase-mz.122-25.SEB2.bin"
VLAN0004
Root ID Priority 32772
Address 0015.628a.c000
This bridge is the root
Bridge ID Priority 32772 (priority 32768 sys-id-ext 4)
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/1 Desg FWD 4 128.1 P2p
Gi2/0/1 Desg FWD 4 128.53 P2p
Access Switch #1
VLAN0004
Aging Time 300
Access Switch #2
C2970 Software (C2970-I6L2-M), Version 12.2(20)SE4, RELEASE SOFTWARE (fc1)
VLAN0004
Address 0013.1a99.0980
Aging Time 300
Gi0/25 Desg FWD 4 128.25 P2p
Gi0/26 Desg FWD 4 128.26 P2p
RANDOM SW1
VLAN0004
Aging Time 300
RANDOM SW2
VLAN0004
Address 0015.2b5b.6300
Aging Time 300
Gi3/0/1 Desg FWD 4 128.105 P2p
Solved! Go to Solution.
01-06-2010 06:14 AM
Mike
This can happen if your trunks are not correctly configured or are not operating properly. You need to check the status of trunk links between access-layer switches and 6500 switches and also which vlans are pruned/allowed on the links.
Jon
01-06-2010 06:14 AM
Mike
Jon
01-06-2010 06:33 AM
Makes sence
CORE
clear trunk 3/9 2,4-6,8-20,22,24-1000,1006-1023
set trunk 3/9 on dot1q 1,3,7,21,23,1001-1005,1024-4094
set spantree priority 8192 3,21,25
3/9 is an uplink to a swithc claiming to be root.
And this matches up the the swithc on the other side of the 3/9 link. Thanks Jon. Now if i config the link on the access switch to:
interface GigabitEthernet3/0/1
sw trunk allowed vlan 1,3,7,21,23,1001-1005,1024-4094 (adding this config line)
switchport mode trunk
end
This should take core of it? Testing i go.
CISCO3750POE-3rdFloor#show spann | i VLAN|This
VLAN0001
VLAN0002
VLAN0003
VLAN0004
VLAN0005
VLAN0006
VLAN0007
VLAN0008
VLAN0009
VLAN0010
VLAN0011
VLAN0012
VLAN0013
VLAN0014
VLAN0015
VLAN0016
VLAN0017
VLAN0018
VLAN0019
VLAN0020
VLAN0021
VLAN0022
VLAN0023
VLAN0024
VLAN0025
VLAN0026
VLAN0027
VLAN0028
VLAN0030
VLAN0031
VLAN0032
VLAN0033
VLAN0034
VLAN0035
VLAN0036
VLAN0037
VLAN0038
VLAN0039
VLAN0040
VLAN0041
VLAN0042
VLAN0043
VLAN0044
VLAN0045
VLAN0050
VLAN0051
VLAN0052
VLAN0053
VLAN0055
VLAN0067
VLAN0080
VLAN0099
VLAN0100
VLAN0101
VLAN0102
VLAN0103
VLAN0105
VLAN0130
VLAN0150
VLAN0151
VLAN0152
VLAN0153
VLAN0154
VLAN0156
VLAN0222
VLAN0237
VLAN0239
VLAN0265
VLAN0266
VLAN0267
VLAN0268
VLAN0272
VLAN0290
VLAN0291
VLAN0292
VLAN0293
VLAN0294
VLAN0295
VLAN0302
VLAN0310
VLAN0311
VLAN0371
VLAN0666
VLAN0700
VLAN0803
