Maintaining/Managing a Network - Preventative Maintenance
Answered Question
Jan 6th, 2010
Hi All,
I manage a network of Catalyst 3750, 3750E & 6500 series switches and various types of routers.  What should I be doing to maintain these network devices in good condition.
I monitor the network for faults.  I update the IOS periodically.  I document changes.
But, what else should I be doing to ensure the smooth operation of the network.  I reviewed the Guides for each device but did not find any real "preventative maintenance" instructions.
Should I shutdown and restart these devices a certain number of times per year?  Vacuum them?
Any input would be helpful.
Correct Answer by sachinraja about 7 years 6 months ago
Jon is spot on. I wouldnt do much with a working box unless it really has some issues with hardware/software etc. as a preventive measure, we would just keep us alerted, if the CPU or memory goes above a certain level.. also, make sure your routers/switches are hardened on the configuration level, to make sure your network doesnt have issues due to configuration mistakes ! thats preventive maintenance again, but on a software level..
Raj
Correct Answer by Jon Marshall about 7 years 6 months ago
blamb wrote:
Hi All,
"If they are not broke then don't fix them" springs to mind
Basically networking devices are designed to be up all the time as without a network you really can't do anything and you pay, certainly with the 6500s, for that availability. I would certainly do a scheduled backup of your configs altho i suspect you are already doing that.
Other basics are controlled LAN rooms, clean with backup power, good air con etc..
Apart from that if you are monitoring network for faults and documenting all changes i think thats a reasonable approach.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Wed, 01/06/2010 - 06:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
blamb wrote:
Hi All,
Jon
Correct Answer
sachinraja Wed, 01/06/2010 - 06:58
  • Red, 2250 points or more
Raj
blamb Wed, 01/06/2010 - 07:47
Thanks for the input.  I am a big fan of
leaving it alone if it's not broke.  But I needed to make sure that was the best approach.  Thanks again!
