Question about statefull inspection on IOS firewall
Jan 6th, 2010
Hi !
I need for test purposes to initiate tcp traffic from my router to the internet
i have set an inspect list on the outbound interface:
router(config)# int eth0
routert(config-if)# ip inspect myfw out
but the tcp sessions initiated from the router are not added int the inspection table and the tcp packets are dropped on their way back
Is there a solution to do this ?
\François
Kent Heide Wed, 01/06/2010 - 08:39
If what you're meaning is traffic initiating from the router itself like for example if you want to telnet from the router you need to add a statement in your `ip inspect` config.
What you need is the `router-traffic` keyword after your inspect configuration.
ip inspect myfw tcp router-traffic
fdubus Thu, 01/07/2010 - 01:55
Thank you!
This is exactly what i was meaning !
Ganesh Hariharan Wed, 01/06/2010 - 08:49
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Related Content
