Unity 7.X VM only, with Failover- general config question(s)
I am setting up a Unity 7.X Voice Mail-only, with Failover deployment. They do not have Exchange in their environemnt so I will be placing Exchange on the Unity server(s). I'm looking at the procedure on CCO and it implies (or I read it as) that the full version of Exchange goes on the secondary server and Administration software for Exchange goes on the primary. So the message store only exists on the secondary/failover? I'm quite confused as to what components go on which servers, and how redundant the end-product is going/suppossed to be.
Also, the general procedure implies that the Failover server should be installed first, is that correct?
Thanks!
Overall Rating: 4 (1 ratings)
Jaime Valencia Wed, 01/06/2010 - 07:15
You can install Exchange on any of them, obviusly the recommendation is the secondary.
Read this:
Requirements for Cisco Unity Failover
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/requirements/7xcusysreq.html#wp472908
Installation Guide for Cisco Unity Release 5.x in a Unified Messaging Configuration with Microsoft Exchange (With Failover Configured)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/installation/guide/umexfo/5xcuigumefox.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
But I'm confused in that it gives an either/or scenario for where the message store is located: Either on the primary or on the secondary, but doesn't give a list of requirements if the message store is located on both. Can it be located on both? The documentation doesn't read that way.
Also, when it mentions about the Subscribers being home on a particular server, is there not some form of replication where both servers have copies of the Subscriber database?
Thanks!
Jaime Valencia Wed, 01/06/2010 - 08:00
The only options are:
Other server
Primary
Secondary
There is no "both" option.
If you want Exchange clustering, separate servers are required. Requirements are on the same link.
If you mean both servers to have the Unity DB, that's the whole point of a failover configuration.
java
