Copy from flash to host on LAN?
Answered Question
Jan 6th, 2010
I'm connecting to a remote location and need to copy a few files off the flash to a host on the LAN so I can update them. I know to go from the lan to the flash I can use
copy tftp://host/file
but is it possible to do the same thing in reverse?
Correct Answer by Ganesh Hariharan about 7 years 2 months ago
Hi Richard,
To Copy file from flash to tftp
Run this command copy flash tftp
check out the below link for more information
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a6744.shtml
Hope that helps out your query !!
Ganesh.H
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Wed, 01/06/2010 - 08:34
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi Richard,
Ganesh.H
Leo Laohoo Wed, 01/06/2010 - 13:19
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Richard,
Don't forget to copy the vlan.dat file (if you are using more than the default VLAN 1).
