CISCO-CONFIG-COPY-MIB question
Answered Question
Jan 6th, 2010
  • Gold, 750 points or more
As a result of network interruption during script execution, some of the remote devices never received the ccCopyEntryRowStatus "destroy", so I assume that field remains set to createAnd*. Would there be any danger leaving that "as is", especially considering the next execution will again attempt to set it to createAnd*? On the flip side, what happens if ccCopyEntryRowStatus receives "destroy" when it's not set (or would that be the "notInService(2)" state)?
Correct Answer by Joe Clarke about 7 years 3 months ago
Yes, you can, and I do in all of my scripts.
No, that won't work.  If a row is in a createAndWait state, it must be set to active, not createAndGo.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 01/06/2010 - 09:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is no danger.  Assuming your next run of the script will do a destroy before trying to reset row objects, you will be fine.  Of course, if you're worried about it, you can always send a destory after the fact, and clean things up now.
yjdabear Wed, 01/06/2010 - 09:22
Is it to say I could summarily issue a blind "destroy" upfront regardless, as a "best practice"?
To restate my original question: Is there any [adverse] impact if ccCopyEntryRowStatus that's left in "createAndWait" state receives another "createAndWait" directive immediately after?
Correct Answer
Joe Clarke Wed, 01/06/2010 - 09:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
