01-06-2010 11:43 AM - edited 03-04-2019 07:08 AM
I need help in converting my E1 internet connection to my router.
I have a modem from my isp which has two bnc connections.... one labeled "in" and one labeled "out" both at E1 75 ohms...
I have a cisco router with an E1 Wic card installed (rj45)...
I need to convert the signal. I have a balun and a 10 base2 to 10 baset converter.
I have tried both individually and am not getting results.
Am I on the right track?? is there something anyone can suggest?? or where to purchase it??
I would really appreciate any help.
Thanx.....Omar
Solved! Go to Solution.
01-06-2010 12:28 PM
VWIC2-1MFT-T1/E1 - 1 PORT RJ-48 MULTIFLEX TRUNK - T1/E1
01-06-2010 11:57 AM
Which card do you have? send "show diag".
01-06-2010 12:28 PM
01-06-2010 01:32 PM
You do not need a balun.
Under controller E1, configure line-termination 75.
Then make an appropriate cable, or buy the cisco one.
Please remember to rate useful post clicking on the stars below.
