??? displays when DND is activated
francisg
Cisco Unified CM Administration
System version: 7.1.3.10000-11
Cisco 7942, 7941, 7962 and 7961 phones
When the DND softkey is pressed, ??? is displayed instead of DND active.
Does anyone have the same issues with DND?
Jaime Valencia
That's a bug
CSCsm35191            Bug Details
7961/41 PLK Issue,DND shows ??? on display
Symptom:
After upgrade CUCM from 6.0.1.2114-1
to  6.1.1.1000-11
Activate DND from 7941/61 IP Phones shows ??? charcters instead of DO not Disturb is Active text display on phone.
SCCP8.3.3SR2S firmware on all Phones.
Conditions:
upgrade from 6.0 to 6.1
You can pass the info to the owner of your PDI case
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
That's a bug
Symptom:
to  6.1.1.1000-11
Conditions:
java
java
This happened on a handful of my 7945 phones too. I'm running CUCM 7.1.3 - not an upgrade either. I forget the phone load I was running but upgrading to 8-5-3S did the trick.
-mike
