Upgrade IOS Problem for C2960
Jan 6th, 2010
There are three 2960 took this problem:
WS-C2960-48TC-S 12.2(25)  2
WS-C2960-24TC-S 12.2(25)  1
upgrade from 12.2(25) to 12.2(50)
upload the IOS by TFTP to flash:
boot system flash:****
wr
reload
Failed to get configuration
Invalid parameter block -- no mac address available.
Xmodem file system is available.
The system has been interrupted, or encountered an error
while non-volatile environment variables were being read
out of flash.  If you interrupted the system, it would be
a good idea to issue the reset command now, or the
environment variables may be lost.  The following
commands will initialize the flash filesystem, and finish
loading the operating system software:
    flash_init
    boot
switch: flash_init
Initializing Flash...
...no flash filesystems found.
than i try to type some command:
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
switch: flash_init
switch:
i try to sent original IOS to null: filesystem and successed, but after reboot nothing happen...
is this a hardware problem? just like flash card get crashed....
any suggestion?
thanks and Best REgards
Overall Rating: 3 (1 ratings)
Leo Laohoo Wed, 01/06/2010 - 21:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Recovery From Corrupt or Missing Software Image on Cisco Catalyst 2900XL and 3500XL Series Switches
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080094955.shtml
sam_chang88 Wed, 01/06/2010 - 23:00
switch: flash_init
no flash:
HOW to do the next?
I say the 2960, not 2900xl
Leo Laohoo Thu, 01/07/2010 - 13:15
  • Hall of Fame,
    2017 LAN, Wireless
Type "i", press enter and try again.  Do you get any output when you type "?"?
PRAVEEN KUMAR GVK Sun, 08/21/2011 - 18:25
hi
me to same problem i am using 2960 l2 switch
how can i upgrade
                                                thanks
Reza Sharifi Sun, 08/21/2011 - 18:48
    2017 LAN
Parveen,
Are you trying to upgrade your IOS or your current IOS does not load?
sam_chang88 Mon, 08/22/2011 - 19:46
only you can do that buy the service of smartnet for the 2960, and change the new one, back the old to factory.
PRAVEEN KUMAR GVK Thu, 05/17/2012 - 03:09
hi
sam there is no ios in ur switch. u have to upload usig xodem in hypererminal.
i did the same it working fine.
regards
praveen kumar gvk.
Related Content
