LMS3.2 connection to databases
Michel Hegeraat
Level 7
Level 7
I created the DSN's as described in the procedure and when I click the test button they says it OK
However if I use an application to connect to these DSN's it says generic:
[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified (SQL-IM002)
I reused the script for local connections to work on a remote via the ODBC but it says the same as other applications when they try to hook up to the DSN
use DBI;
my ($dbh, $cur, $sqlstr);
my $connString = "dsn=cmf;uid=lmsdatafeed";
$dbh = DBI->connect('DBI:ODBC:DSN', $connString, 'didata', {PrintError => 1});
if ($dbh) {
   my $sqlstr = "SELECT Device_Id, Device_Display_Name, Management_IPAddress FROM Network_Devices";
   my $cur = $dbh->prepare($sqlstr);
   $cur->execute if ($cur);
   while (my $rs = $cur->fetchrow_arrayref) {
      my ($devId, $dispName, $ip,) = @$rs;
      print "Device_Id: $devId\n";
      print "Device_Display_Name: $dispName\n";
      print "Management_IPAddress: $ip\n";
      print "--------------------------------------------\n";
   $cur->finish;
   $dbh->disconnect();
Does anyone see what I miss here?
Cheers,
Michel
5 Replies 5
Joe Clarke
What are all of the parameters you specified for the cmf data source?
Let's start with ani
on the tab ODBC
Data source name:      ani
Descrioption:              ani
on the tab Login
User ID:                      lmsdatafeed
Password:                  didata
on the tab Database
Server Name:              aniEng
Database name:          aniDb
on the tab Network
TCP/IP:                       HOST=wk3-lms;DOBROADCAST=NO;ServerPort=43443
and cmf
on the tab ODBC
Data source name:      cmf
Descrioption:              cmf
on the tab Login
Password:                  didata
on the tab Database
Server Name:              cmfEng
Database name:          cmfDb
on the tab Network
TCP/IP:                       HOST=wk3-lms;DOBROADCAST=NO;ServerPort=43441
Within the ODBC properties, you don't need to specify the username/password.  That is set when you run the dbaccess.pl script on the server.  Other than that everything looks okay.  Make sure you can telnet to TCP port 43441 from the client to the server.
Thanks Joe,
I thought the "Test Connection" button may need a username/password
Telnet to that port works.
Can't drop that session from the cli it seems
Cheers,
Michel
All of this checks out.  Make sure the proper DLLs are installed on the client per the database access instructions.  You can also try sniffing the traffic between the client and server to see if a connection is being attempted.  If not, this could point to a client ODBC issue.  You might try starting over on a new client to rule out any problems.
