problem with VPN GRE and IOS Firewall
Answered Question
Jan 6th, 2010
Hello. I have a problem with a Cisco 2800 Router. I can't connect from the inside network to outside using a GRE VPN client (MS). I did a packet capture and responses are coming on the outside interface but they never reach the inside interface. I allowed both IP protocol 47 and TCP 1723. I've attached the running config. Please help.
Correct Answer by Claudiu Boar about 7 years 4 months ago
Overall Rating: 5 (1 ratings)
fbhura Thu, 01/07/2010 - 20:34
hi ,
     you would require that you open up GREon the outside interface.
access-list ex 199 permit gre any any
that should take care of it.
Faisal Bhura
sergiu.campian Thu, 01/07/2010 - 23:15
It doesn't work with the acl only, but the method described in the link above with the inspection policy did the trick. Thanks.
