RME 4.31 inventory collection failed on 122-33SXI3
Answered Question
Jan 6th, 2010
I have the same issue with IOS 122-33 SXI3  running on 6513.
RME unable to collect the inventory details eventhough updated to LMS 3.2 .
RME version : 4.3.1
Is any workaround to solve this issue on LMS 3.2
Dileep
Correct Answer by Joe Clarke about 7 years 5 months ago
Go to RME > Devices > Device Management > RME Devices, and edit the device attributes for this switch.  Do an inline edit, and increase the SNMP timeout to 10 seconds.  Save the changes, then apply them on the previous screen.  Inventory collection will then work.
Overall Rating: 5 (2 ratings)
Joe Clarke Thu, 01/07/2010 - 00:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the IC_Server.log after performing an inventory collection for this device.
Correct Answer
Joe Clarke Thu, 01/07/2010 - 09:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Dileep Sivadas ... Thu, 01/07/2010 - 22:08
Yes , it worked .
can you please clarify why this happend, is it due to LMS or IOS.
There were two changes
1. upgraded  IOS to 122-33SXI3 from 122-18 SXF16.
2. upgraded LMS 3.1 to 3.2
Joe Clarke Thu, 01/07/2010 - 23:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The need for this is due to IOS, and the time it takes to process requests for the CISCO-FLASH-MIB on this platform and version of code.
acharyr123 Wed, 03/17/2010 - 00:15
Hi Clarke,
I am also facing the similar issue with IOS 12.2(33) SXI1, the Core Switches are in VSS mode. Inventiry collection shows failed for these devices. I am using LMS 3.1 with the following submodule versions:
NameVersionLicense StatusSize
CiscoWorks Common Services3.2.0LicensedNot applicable
Campus Manager5.1.0Purchased5000
CiscoView6.1.8LicensedNot applicable
CiscoWorks Assistant1.1.0LicensedNot applicable
Device Fault Manager3.1.0Purchased5000
Internetwork Performance Monitor4.1.0Purchased5000
Integration Utility1.8.0LicensedNot applicable
LMS Portal1.1.0LicensedNot applicable
Resource Manager Essentials4.2.0Purchased5000
Joe Clarke Wed, 03/17/2010 - 17:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If the information in this thread did not solve your issue, then start a new thread for your specific problem.
gnijs Wed, 08/11/2010 - 02:45
  • Bronze, 100 points or more
Solved it for us too :-) thanks.
Geert
Related Content
