SNR Extension mobility
Jan 7th, 2010
Can I use mobility / single number reach as the same time as using extension mobility. I had a go at setting this up and found I had to turn EM off to enable the owner user id on the phone
thanks
Adam Thompson Thu, 01/07/2010 - 06:21
  • Silver, 250 points or more
Yes, you can use extension mobility and SNR at the same time. For SNR to work, you shouldn't have to enter a userID in the device configuration. SNR is not based on the phone device, it is tied to the users extension.
