Cisco 1941 HWIC Throughput
Jan 7th, 2010
Can anyone confirm that the new 1941 routers now handle Gigabit at wire speed using the HWIC-1GE-SFP module?  The data sheet doesn't make it clear, see extract below:
  • Each HWIC Slot offers high data throughput capability
  • Up to 1.6 Gbps aggregate towards the router processor (?)
Thanks in advance,
Andrew
Paolo Bevilacqua Thu, 01/07/2010 - 04:18
None of the ISR routers, either G1 or G2 comes even close to Gigabit speed.
Check attached document. Allow some 20% performance improvement for the G2s.
If you need gigabit wire speed, use a L3 switch.
