Compliance template failure using Prerequisite Command Set
Disc01079
Is het my failure in reasoning or is CIscoWorks LMS 3.2 here at fault?
After reading the whitepaper "CiscoWorks Resource Manager Essentials Compliance Management"
I tried to use the "Prerequisite Command Set" in order to check the compliance of the trunk
interface configuration. I created therefore the following template where I check for the
existance of the statement "switchport mode trunk":
Name: Global     SubMode: No      isPrerequisite: No
Ordered : No     Prerequisite-Commandset : none     Parent: none
Name: InterfaceTrunk     SubMode: Yes      isPrerequisite: No
Ordered : No     Prerequisite-Commandset : none     Parent: Global
  interface   [#.*Ethernet.*#]
# check trunk ports
Name: IntTrunkPrereq     SubMode: No      isPrerequisite: Yes
Ordered : No     Prerequisite-Commandset : none     Parent: InterfaceTrunk
+switchport mode trunk
Name: IntTrunk     SubMode: No      isPrerequisite: No
Ordered : No     Prerequisite-Commandset : IntTrunkPrereq     Parent: InterfaceTrunk
  +  [#description   .*#]
  +   load-interval   50
The Job results are that for every interface I receive the addition suggestion:
+interface FastEthernet0/1
    +   load-interval 50
regardless whether the configuration contains "switchport mode trunk" or "switchport mode access".
I tried some other variants with the same result. So does anyone know what's wrong in my reasoning here?
I'm using CWLMS 3.2 with RME 4.3.0
Kind regards,
Dick Hogeweg
Joe Clarke
This is wrong.  You need to combine the submode and prereq commandlets into one:
Submode : interface [#.Ethernet.*#]
IsPrereq : Yes
Body:
+ switchport mode trunk
Parent : TrunkPorts
Prereq : TrunkPorts
Body:
+ load-interval 50
Joe Clarke
IsPrereq : Yes
Body:
Parent : TrunkPorts
Prereq : TrunkPorts
Body:
+ load-interval 50
Hi Joe,
This is indeed the solution. What threw me off balance was the fact that when you construct the template I got an error "A commandlet cannot be its own prerequisit". This happens when you first create your prereq, save it, click on your prereq link at the Command set column, click on add and create and save the comandlet with prereq as prerequisit. But I can work around this error and then everything works fine. Thanks for your help,
Dirk
Another thing thing to be aware off is that you can't group prerequisites command sets into a parent command set (ie Interfaces). This makes the prerequisites command sets effectless. Cheers,
Dirk
