UC520 - E1 R2 - Venezuela (MOVISTAR)
Greetings,
i need configure an e1 card on UC520-24U-8FXO-K9, but the info founded to make it is not complete, i don't sure what is wrong
The e1 is up but i can't send or recive calls,and i don't know how associate the trunk pstn trunks.
that is the info suplied by the PSTN company:
Signal: Q.421 (R2)
-Signal IN: MFC-R2 (7 Lines IN)
-Signal Out: DTMF o MFC-R2 (8 Lines Out)
Header: 2514200000
Numbers: from 2514200000  to 2514200099
This is the configuration that places:
card type e1 0 2
network-clock-participate wic 2
trunk group ALL_T1E1
hunt-scheme longest-idle
controller E1 0/2/0
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital r2-compelled ani
ds0-group 1 timeslots 17-31 type r2-digital dtmf dnis
cas-custom 0
  country venezuela
  answer-signal group-a 6
  dnis-complete
process-max-time 50
voice-port 0/2/0:0
voice-port 0/2/0:1
Thanks in advance by your help.
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Thu, 01/07/2010 - 08:35
  • Hall of Fame,
    Founding Member
Begin sending "show controllers E1"
UC520#sh controllers e1
E1 0/2/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20090408, FPGA: 13, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (98 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     1033 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     1033 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
UC520#
Paolo Bevilacqua Thu, 01/07/2010 - 12:31
  • Hall of Fame,
    Founding Member
You need "network-clock-select 1 e1 0/2/0"  to eliminate slip.
The you need the dial-peer configuration, do you know what it means ?
I have a VZ movistar site, but not here, can look into it tomorrow.
I include the "network-clock-select 1 e1 0/2/0"  and avoid the splits, thanks, and i hope compare to your VZ movistar site configuration, thanks again.
I don´t configure the e1 associates dial-peers yet, nor the trounk group all_t1e1, i don't know how for e1 configuration.
that is the dial-peer configuration:
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number .%
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 100 pots
dial-peer voice 101 pots
dial-peer voice 102 pots
dial-peer voice 103 pots
dial-peer voice 150 pots
port 0/3/0
dial-peer voice 151 pots
port 0/3/1
dial-peer voice 152 pots
port 0/3/2
dial-peer voice 153 pots
port 0/3/3
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 199
b2bua
voice-class sip outbound-proxy  ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 104 pots
destination-pattern A4
no sip-register
dial-peer voice 105 pots
destination-pattern A5
no sip-register
dial-peer voice 106 pots
destination-pattern A6
no sip-register
dial-peer voice 107 pots
destination-pattern A7
no sip-register
dial-peer voice 154 pots
destination-pattern A8
port 0/3/0
no sip-register
dial-peer voice 155 pots
destination-pattern A9
port 0/3/1
no sip-register
dial-peer voice 156 pots
destination-pattern A10
port 0/3/2
no sip-register
dial-peer voice 157 pots
destination-pattern A11
port 0/3/3
no sip-register
no dial-peer outbound status-check pots
Paolo Bevilacqua Fri, 01/08/2010 - 09:30
  • Hall of Fame,
    Founding Member
You do not have DP for the digital ports, and to muich confusing and unnecessary DPs and cor-list.
Recommend you locate a certified partner or reputable consultant to help you.
Sorry, my coworkers with access to VX site have left for the day.
its because are the the default configuration make it by the CCA interface, i think will be needed showed,
i can't configrue digital DP until associate the trunk-group to voice-ports i think..
do you know another doc or sample to trunk-group, voice-ports and dps digital? that i founded isn't usefully
please let me know whe you find the VE movistar configuration to compare
thks again
Paolo Bevilacqua Mon, 01/11/2010 - 06:10
  • Hall of Fame,
    Founding Member
Below what we use for Movistar. I suspect come coammnds are not needed and could have left to defaults.
You don't need trunk-groups for normal use. If you use CCA, you will never get it working. Study the CLI or hire someone qualified.
Please remember to rate useful post clicking on the stars below.
controller E1 0/1/0
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital dtmf dnis
ds0-group 1 timeslots 17-31 type r2-digital r2-compelled ani
cas-custom 1
   country venezuela
   debounce-time 10
   release-guard-time 10
   reanswer-time 1000
   dnis-digits min 4 max 4
   answer-guard-time 1
Paolo Bevilacqua Mon, 01/11/2010 - 07:03
  • Hall of Fame,
    Founding Member
DP are not specific for Movistar.
You really need to study cisco voice configuration, or give the job to someone that knows.
Otherwise you will only get very poor resultaùs, and an angry customer.
