SSH access
Jan 7th, 2010
I have approximately 500 remote sites. They are primarily 5505's connecting to us as EzVPN clients. I have the outside interface configured for SSH, but I get a network connection error any time I try to connect to any of the sites. Below is my config, could someone tell me what I am missing to be able to SSH into these devices?
ASA Version 8.0(3)
hostname xxxxxxxx
domain-name xxxxxxxx.com
enable password xxxxxxxx encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address x.x.x.x 255.255.255.192
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.252
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxxxxxxx encrypted
boot system disk0:/asa803-k8.bin
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server x.x.x.x
name-server x.x.x.x
domain-name xxxxxxx.com
pager lines 24
logging enable
logging timestamp
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http x.x.x.x 255.255.255.192 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
vpnclient server xxxx.xxxx.com
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup xxxx password ********
vpnclient username xxxx password ********
vpnclient enable
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:5c86d7e9a681ff69bca5e
: end
Ganesh Hariharan Thu, 01/07/2010 - 09:04
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
By default, the security appliance             allows both SSH version 1 and version 2 but for trouble shooting purpose configure a specific version 2 in ASA  and then share the result.
Ganesh.H
Richard Burts Sat, 01/09/2010 - 20:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
George
First a question: have you generated the RSA keys on the ASA which are needed to support SSH?
Second a suggestion: if you have configured the RSA keys and SSH does not work, then I suggest that you configure at least one user & password on the ASA, and then configure authentication of SSH specifying LOCAL as the authentication source.
Rick
