Can we move Unity message store without Unity re-install?
Answered Question
Jan 7th, 2010
We are upgrading Exchange 2000(on new hardware) to Exchange 2003.  Can we essentially "move" the message store from 2000 to new 2003 server without having to re-install Unity?  Or do we have to re-install Unity?
Correct Answer by Jaime Valencia about 7 years 1 month ago
Version???
Message store onbox?? offbox???
I suggest you take a look at this link and the topics it covers.
Reconfiguration and Upgrade Guide for Cisco Unity Release 5.x (With Microsoft Exchange)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcurugex.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (3 ratings)
Tommer Catlin Thu, 01/07/2010 - 09:53
Sounds like it is offbox UM with Unity.  If that is the case, you will install the system management tools for Exchange 2003 and Sp2, etc on Unity.  Then re-run permissions wizard (download latest from unitytoolsdepot).   Then run the message store wizard from add/remove programs to add in the stores from 2003.
Wait for AD/Unity/SQL to sync everything up.   Once it is tested with 2003 (move one mailbox and test mwi, etc) then you can plan on moving others when time permits.
Rob Huffman Thu, 01/07/2010 - 11:13
Hey Daniel,
Long time my friend Hope all is well with you,
it's -26 here this morning (yikes). I heard that it is very
cold in your neck of the woods as well, I guess it's all
relative.
You can't receive answers from two better NetPro's than Tommer
and Java (awesome work guys!) , but  I thought you may want to read
another thread just in case;
From Ginger (one of my faves)
https://supportforums.cisco.com/message/1212647#1212647
Take care! Cheers!
Rob
