Locate DN via external calling mask field?
Answered Question
Jan 7th, 2010
Call Manager version 6.1
Is there a command to locate a dn by querying the database on the external calling mask field?  Please help or I will have to search through 400 lines manually!!!
Correct Answer by Jaime Valencia about 7 years 1 month ago
I believe that's the e164mask field from the devicenumplanmap table.
You can run the qry on CLI.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
