SSH 2 for connecting to the AIP-SSM module
Jan 7th, 2010
I have not found any documentation on the version the module is using but I'm able to connect with SSH1 & SSH2.. is there a way of disabling SSH1 and allowing only SSH2??
Thanks and regards,
conmurph Sun, 01/10/2010 - 17:28
I don't think this feature is currently supported. Hopefully someone else on the forum might be able to find a document to share with you.
andrey.dugin Mon, 01/11/2010 - 01:08
You may check it. Create service account and then login to appliance. You will see the Linux and you may edit sshd_config for your needs.
