Cisco IOS ZFW (Zone Based Firewall) and IPsec VTI
ROBERTO TACCON
Level 4
Level 4
Hi to all,
with IPSEC VTI how I can configure the phase 2 proxy-id ?
"The best part of the whole thing is NO CRYPTO MAPS"
HOW traffic is associated with a remote site ? using "ip route" static routes rather than mirrored ACLs ?
Need the configure the routing / the policy map ?
Following the configuration (Need to configure a VPN between host 10.1.1.1 host 192.168.1.35):
crypto isakmp policy 1
encr aes 256
authentication pre-share
hash sha
group 2
lifetime 3600
crypto isakmp key 0 cisco address 1.1.1.1 no-xauth
crypto isakmp keepalive 10
crypto ipsec security-association lifetime seconds 28800
crypto ipsec transform-set ACI esp-aes 256 esp-sha-hmac
crypto ipsec profile VTI
description ** VPN IPSEC L2L to ACI **
set transform-set ACI
set pfs group2
set security-association lifetime seconds 28800
interface Tunnel2
description *** test VPN IPSEC with ACI
ip address 192.168.10.2 255.255.255.0
ip ospf mtu-ignore
zone-member security untrust
ip policy route-map ROUTING-POLICY-1.1.1.1
tunnel source 2.2.2.2
tunnel mode ipsec ipv4
tunnel destination 1.1.1.1
tunnel protection ipsec profile VTI
route-map ROUTING-POLICY-1.1.1.1 permit 10
match ip address 147
access-list 147 remark *** ACL VPN 1.1.1.1
access-list 147 permit ip host 10.1.1.1 host 192.168.1.35
ip route 192.168.1.35 255.255.255.255 Tunnel2
Joe B Danford
Static VTIs, which is what you are using on this router only supports an "ip any any" proxy id. You will not need to configure one here. Traffic is sent over the tunnel using routing protocols or static routes. The following route should be good enough
If you are having problems configuring the tunnel than I would check the policy on the remote end. If they are not using SVTI or a ip any any proxy ID then this will not work.
