Buzz door open by using IP Phone???
Paolo Bevilacqua Thu, 01/07/2010 - 14:42
You need an FXS port and a "PBX / intercom interface box".
The latter can be bought online or in telecom supplies store.
The product is for intercom, right??  Can I use that to buzz the door open by pushing the button on the phone???
Here is the situation, there is a glass door at our department, so we can see the people stand outside.  I just want to something to intergrate with our CUCM 6.12 (Skinny, NOT SIP), so we can push a button at the IP Phone to open the door.
rob.huffman Fri, 01/08/2010 - 09:01
Hi Ken,
No worries my friend
The C-1000b won't work on it's own. Wouldn't you want to be able
to check who is @ the door via the Intercom first before buzzing them in?
If this is a locked door, then it must be for a reason. The whole concept
is based on an active phone call between the door and the respective IP phone
and then using DTMF to activate the door stricker mechanism to unlock
the door. If you don't use an Intercom then there will be no way to intiate a call
to the IP phone to start the process.
The door is a glass door and the visitors already through security checkpoint, so they just dont want to walk to the door and open it.
They just want to open the door without getting up.
Well, if those two products have to work together, then thats fine.  I am just wondering if there is door buzz feature without intercom module.
Jun Sarceno Thu, 03/28/2013 - 12:50
Hello Rob,
       I have the exact setup like what you mentioned above.  I have a W3000 and C-1000B.   I was told by Viking that I cannot set up an ATA with this device because the ATA will not work with W3000.  In addition, they told me I need a FXO and not an FXS.  I have the FXO.   Can you give me some directions on how to configure the ATA to work with the equipment above?  Thanks in advance.
love2xlr8 Fri, 10/04/2013 - 13:40
I'm in the exact situation, were you able to find a solution ? if you did could you provide me with the product you chose and how it working ?
Jun Sarceno Fri, 10/04/2013 - 14:44
I had to use a FXO card to interface with the Viking C-1000B and W3000 Door Buzzer.
On the router with FXO card:
voice-port 0/1/0
connection plar 1100 <==number to ring when someone buzzes in.
description Door Buzzer
station-id Door Buzzer
voice-port 0/1/1
dial-peer voice 1 pots
port 0/1/0
dial-peer voice 2 voip
destination-pattern 1100
session target ipv4: <== your call manager
codec g711ulaw
interface GigabitEthernet0/0
description LAN Interface
ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
no mop enabled
h323-gateway voip bind srcaddr
Create a H323 Bind on your router:
     h323-gateway voip bind srcaddr <== router IP
Create H.323 gateway on call manager and point to the router
Then if you need to transfer it to a DN that is being manned, create a partition, CSS and translation..
Hope this helps.
asotojimenez Fri, 07/11/2014 - 15:05
Could you help me set up a Call Manager Express
I have
1 W-1000-EWP (connected to an FXS port)
1 RC-24
I want to do this.
Pressing the button on the intercom (W-1000-EWP) ringing all, would like a ring that someone is at the door IP phones.
Reply from any IP phone by dialing the extension 36 to the intercom
Open the door with the extension 6
For this requirement did the following:
I did a HUNT-GROUP in parallel mode and assign all extensions
a pilot number 601
When I put a FXS port coonnection-plar 601
601 pilot number assigned to all extensions as a secondary extension
But I have not been successful because only sounds the phone every time I press the call button of the intercom.
Annex part of the configuration:
In the FXS port where I connect the intercom viking
voice-port 0/0/3
cptone MX
connection plar 601
description conexion del intercom
station-id name intercom
 station-id number 36
caller-id enable
voice hunt-group 10 parallel
list 20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35
pilot 601
ephone-dn  300  dual-line
number 20 secondary 601
pickup-group 1
label YOYIS 20
description yoyis
name YOYIS
dial-peer voice 10 pots
destination-pattern 36
port 0/0/3
I'm doing wrong?
