LMS 2.6, cannot start process syslogAnalyzer
Answered Question
Jan 8th, 2010
I'm unable to generate any syslog reports. an error is received when I see the collectot status
> Error
Collector Status is currently not available
Check Whether SyslogAnalyzer process is running normally
The following is the Analyzer status
    Process= SyslogAnalyzer
    State  = Administrator has shut down this server
The syslog.log file receives the logs. The syslogCollector log indicates the following error,
Could not send syslogs, removing the subscriber...Connection refused: connect
NMSROOT is C:/PROGRA~1/CSCOpx propFileC:/PROGRA~1/CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\C:\PROGRA~1\CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\csc\data\Collector.properties
SyslogCollector - [Thread: main] INFO , 22 Dec 2009 15:20:00,046, Logging System Initialized.
SyslogCollector - [Thread: main] INFO , 22 Dec 2009 15:20:00,046, System Initialized.
SyslogCollector - [Thread: main] WARN , 22 Dec 2009 15:20:08,640, Unable to resurrect connection to a subscriber.
SyslogCollector - [Thread: main] INFO , 22 Dec 2009 15:20:08,718, Service started...
Resubscring the Analyzer to the collector doesn't solve the issue.
When enabling the analyzer process manually, it throws an error
"Error: cmd failed. Server reason:"
can anybody help in fixing this?
Thanks in advance
Correct Answer by Joe Clarke about 7 years 2 months ago
Post a screenshot of your Services control panel showing all of the CiscoWorks services along with the output of the "hostname" command from a server DOS prompt.
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 01/08/2010 - 09:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the entire SyslogCollector.log, AnalyzerDebug.log, SyslogAnalyzer.log, and output of the command:
netstat -a -n -o -b
rajesh_san Thu, 01/14/2010 - 06:26
Hi Joe, i've attached the files. But netstat command seems not to be taking
C:\>netstat -a -n -b -o
Displays protocol statistics and current TCP/IP network connections.
NETSTAT [-a] [-e] [-n] [-s] [-p proto] [-r] [interval]
Also, nothing was written to the AnalyzerDebug.log file.
Joe Clarke Fri, 01/15/2010 - 14:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Ah, you're on Windows 2000.  Post the output of "netstat -a -n" and the SyslogAnalyzer.log.
rajesh_san Sun, 01/17/2010 - 04:57
Hi Joe,
The outputs are included in the attachemetn outputs.zip poster earlier in reply.
Joe Clarke Sun, 01/17/2010 - 14:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Jrm is not working.  Post the jrm.log.
Correct Answer
Joe Clarke Mon, 01/18/2010 - 11:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
rajesh_san Fri, 01/22/2010 - 08:25
Hi Joe, Thanks for pointing it out. The service startup parameters were modified and after setting the same correctly, the jrm process came up and everything is fine now
