Problem to display the Caller ID with the sip Trunk
Jan 8th, 2010
I try to pass the directory number to the sip trunk instead of the user id but it don't work.
I found the procedure in the SPA 9000 Voice System V6-1 ... pdf file.
Here is the Line 1 configuration :
Proxy and Registration
Proxy:
Outbound Proxy:
Use Outbound Proxy:yesnoUse OB Proxy In Dialog:yesno
Register:yesnoMake Call Without Reg:yesno
Register Expires:Ans Call Without Reg:yesno
Use DNS SRV:yesnoDNS SRV Auto Prefix:yesno
Proxy Fallback Intvl:Proxy Redundancy Method:NormalBased on SRV Port
Mailbox Status:Mailbox Subscribe URL:
Mailbox Deposit URL:Mailbox Subscribe Expires:
Mailbox Manage URL:VMSP Bridge:NoneAllAll+Self
CFWD Bridge Mode:noneallXFER Bridge Mode:noneallall except same line
Here is the SIP configuration :
PBX Parameters
Proxy Network Interface:LANWANProxy Listen Port:
Multicast Address:Group Page Address:
Max Expires:Force Media Proxy:yesno
Proxy Debug Option:none1-line1-line excl. OPT1-line excl. NTFY1-line excl. REG1-line excl. OPT|NTFY|REGfullfull excl. OPTfull excl. NTFYfull excl. REGfull excl. OPT|NTFY|REG
Call Routing Rule:
Call Park MOH Server:Call Park DLG Refresh Intvl:
Default Group Line:Group 1 User ID:
Group 1 Line:Group 2 User ID:
Group 2 Line:Group 3 User ID:
Group 3 Line:Group 4 User ID:
Group 4 Line:
Hunt Groups:
SIP DIDN Field:TO UserIDTO ParamSIP DIDN Param Name:
Accept All MWI As Line:Current1234Phone DLG Refresh Intvl:
Followin the recommandations, I changed SIP DIDN Field to "To Param" and SIP DIDN Param Name to "didn" in the Voice > SIP page, PBX Parameters section.
I should see something like this in my syslog server :
INVITE sip:[email protected] SIP/2.0
To: <sip:[email protected]>;didn=4089993003
but there are no information related to the didn :-(
Do you have an idea ?
Thanks you in advance,
Thierry
Alberto Montilla Mon, 01/11/2010 - 10:09
  • Cisco Employee,
Dear Sir;
Do you have the mapping done in the Contact List:? i.e. :+?
regards
Alberto
thierry.berwart_2 Tue, 01/12/2010 - 05:29
Hi !
Thanks you for your reply!
Yes i filled the contact list in the Line 1 page :
Subscriber Information
Display Name:User ID:
Password:Use Auth ID:yesno
Auth ID:Call Capacity:unlimited123456789101112131415
Contact List:
Cfwd No Ans Delay:
But I thought it's used only for the incoming calls ?
And in the logs, I don't see the information related to the didn in the "invite .. to ... " sip message
Thierry
Alberto Montilla Tue, 01/12/2010 - 07:27
  • Cisco Employee,
Dear Sir;
Please provide me the logs and network traces to check what the issue could be.
Alberto
