fademidun Tue, 04/24/2012 - 02:34
Please where can I download this software, I can't seems to find the link.
Can you please help with download link
joean Tue, 01/12/2010 - 18:42
Sorry, you can't.
You can only install it on a 32-bit platform.
Even if you managed to install it to a 64-bit platform, you will have consistant fabric discovery failure.
I was able to get Fabric Manager 5.01a installed on Windows 7 Ultimate 64-bit, with User Account Control enabled.  I used the following steps:
1.  Open a command prompt (cmd.exe) as administrator.  Right-click, Run As Administrator.  This is important.
2.  Change to your Java directory (i.e., "C:\Program Files (x86)\Java\jre6\bin").  I used Java version 1.6.0_18-b07.
3.  Run the command "Java.exe -Xmx512m -jar m9000-fm-5.0.1a.jar"  (You'll need to specify the full path to the jar file for Fabric Manager.  On the CD image download, it's in the Software folder).  Your command prompt should look something like this, depending on where the Fabric Manager jar file is located:
C:\Program Files (x86)\Java\jre6\bin>Java.exe -Xmx512m -jar "C:\m9000-cd-5.0.1a\software\m9000-fm-5.0.1a.jar"
4.  Then just follow the steps for the install.
5.  Tada, it's installed.
cfbrooks610 Wed, 04/13/2011 - 09:15
Thanks Willam!!! That worked PERFECT for me!! running Windows 7 Professional (64bit).
andlevin Tue, 12/24/2013 - 07:47
Fabric manager has been renamed to DCNM, you can download off Cisco.com/go/DCNM - you can download client package separately
Trending Topics: Storage Networking
