01-08-2010 09:20 AM - edited 07-03-2021 06:24 PM
How can i know if un AP1240AG this in mode autonomous or mode lightweight????
Solved! Go to Solution.
01-09-2010 02:13 PM
1. Look at the logs for any sign of the word "JOIN". If this is visible, then you are running one of the two LWAP images;
2. Look at the file being used. If the filename has "rcv" then you are using the LWAP recovery image.
3. If you are running an LWAP image (full or "rcv") you will NOT be able to save your config.
01-10-2010 05:39 PM
The methods Leo has mentioned are good ones. Another easy way is to look at the image name in a 'show version' output. If the image name contains:
1) k9w7 - it is autonomous
2) k9w8 - it is lightweight
-Matt
01-09-2010 02:13 PM
01-10-2010 05:39 PM
-Matt
01-13-2010 07:11 AM
Thanks a lot, was very useful
