Is ACS version 4.2 downloadable from Cisco's webiste?
Jan 8th, 2010
We currently have ACS 4.1 but want to upgrade to 4.2 or maybe just totally re-install 4.2 instead of upgrading. Is there a location on Cisco's site where I can download the 4.2 files? I tried downloading one from here but after trying to install the files I found out that wasn't the actual file it was just an upgrade.
http://tools.cisco.com/support/downloads/go/ReleaseType.x?optPlat=&isPlatform=Y&mdfid=281458142&sftType=Secure+Access+Control+Server+%28ACS%29+for+Windows&treeName=Security&modelName=Cisco+Secure+Access+Control+Server+for+Windows+4.2&mdfLevel=null&treeMdfId=268438162&modifmdfid=null&imname=&hybrid=Y&imst=N
Kent Heide Fri, 01/08/2010 - 14:35
That depens on your service agreement level. Most likely it is not available to you as major and minor releases of the ACS never is.
Jatin Katyal Sun, 01/10/2010 - 02:37
  • Cisco Employee,
HI George,
None of ACS's regular version is avaivlable on cisco.com. You can just download evaluation/trial version of ACS 4.1 and 4.1 valid for 90 days.
You can also download any patch you want from cisco.com.
Since you are looking for ACS version 4.2.0.124 (regular version). You need to work with TAC by opening up a case because they can only publish you this version after checking your contract detail.
ACS version 4.2.1 is avaible on cisco.com but that can only be upgraded on ACS version 4.2.0.124 (it should be pre-installed)
JK
Plz rate helpful posts-
