CME Inquiry
Jan 8th, 2010
Hi All,
   I got a few questions below:
  1.Is it possible to deploy CCME on HQ and IP Phone at the brach connect to this CCME?
  2. I got 3 main sites and I would like to deploy 3 ccme on each site, but i don't want to use my WAN router as my ccme instead use another
  2851  and configure the ccme on that router. I want to this because I want to offload the wan router. If it's possible, the setup I want will be like this:
  CCME1 => switch1 =>WAN router1 =====>WAN router2=>switch2=>CCME2
I want to know if how will be the voip dial-peer works on this setup and how should I configure it as I see many sample that CCME is directly connected    via WAN router.
3. I want to apply a E1 pri for the PSTN connection, I want to have one number for the calls going IN and OUT to my network and also one number for the fax. How should I tell this to telco?
Appreciates to your all response! Happy New Year!!
