Twingig Conversor does not reconnect after reload ou power on.
Jan 8th, 2010
Hi Folks,
I have three switches on cascading as you can see attached but when I need to reload or power off and power on late the uplink couldn't link up and I need to remove and put in again the CAB-SFP-50CM as you can see attached to reconnect the uplink.
Anyone know how can I fix this issue?
I am using the twingig conversor module with 3560-e.
thanks a lot
Giuseppe Larosa Sat, 01/23/2010 - 12:21
  • Hall of Fame,
    Founding Member
Hello Daniel,
you are clearly in a lab environment and you have interconnected your switches in this peculiar way.
Probably the problem origins from using this special cable with the twingig
For example I've found the following notes:
When a Catalyst 3560 Switch is connected to a Catalyst 3750 or any           other type of Catalyst switch model, you cannot use the           CAB-SFP-50CM= cable. You can connect both switches using a copper cable with           SFP (GLC-T) on both devices instead of a CAB-SFP-50CM= cable.
Only Catalyst 3560-E switches. The SFP module patch cable is a 0.5-meter, copper, passive cable with SFP module connectors at each end. The patch cable can connect two Catalyst 3560-E switches in a cascaded configuration.
However, your setup is considered a valid setup see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/hardware/install/notes/1757202.html#wp121341
Table 1     Supported SFP Modules
SFP Module Number
Description
GLC-GE-100FX
100BASE-FX
GLC-LH-SM
1000BASE-LX
GLC-SX-MM
1000BASE-SX
GLC-T
1000BASE-T
GLC-ZX-SM
1000BASE-ZX
GLC-BX-D
1000BASE-BX, 1490 nm1
GLC-BX-U
1000BASE-BX, 1310 nm
CWDM-SFP-xxxx
CWDM SFP
DWDM-SFP-xx.xx
DWDM SFP
CAB-SFP-50CM (3560-E only)
SFP module patch cable2
1 nm = nanometer
2 The Catalyst 3560-E switch supports the SFP module patch cable, a 0-5-meter, copper, passive cable with SFP module connectors at each end. The patch cable can connect two Catalyst 3560-E switches in a cascaded configuration.
the special cable is on the list.
Hope to help
Giuseppe
glen.grant Sat, 01/23/2010 - 14:16
  • Purple, 4500 points or more
   Must be something with that twin gig conversion module , we use those copper sfp gbic connecting cables on a plain 3560 and works fine . We have dozens setup that way .
