Wireless Control System - Map Editor Pixilation
Jan 8th, 2010
We are setting up our UWN for location, when installing a building floor into the WCS we are having issues with the image quality.
Although the WCS will display the map correctly in the floor view, when we try to open it using the map editor, the image pixilation and the quality is very poor so we are unable to correctly add the obstacles.
If we try to add an image with a higher DPI the image quality becomes worse.
Are there any recommendations for importing a map into the WCS for this purpose?
takezomurasaki Fri, 12/10/2010 - 12:35
I am having a similar issue.
In addition to the pixilation, if the image dimensions are too large (4200x2400) the aspect ratio is correct in WCS, but then in MapEditor it becomes distorted.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
