WFM OOC service unable to connect to UCCX db
Jan 8th, 2010
Hi all,
I'm trying to understand what method (i'm assuming SQL query) and credentials is OCC Service in WFM is using when connecting to UCCX db (for automated 30 minutes historical data extraction). There's a couple of system DSN created during install (acdDbMain, acdDbBackup) which has been setup for NT authentication.
There's no requirement during installation/config to create NT/SQL user on UCCX/both server to allow this access. The error i'm getting is relatively generic sql error 18452 login failed for user "null" in the ooc logs. I'm getting the same error when OOC process (for old historical data capture) manually.
I'm currently running wfm833 and uccx701sr5 (db in windows authentication mode)
Any ideas? Thanks!
-JT-
Tanner Ezell Mon, 01/11/2010 - 15:33
I believe the entire datastore has to be setup for NT Authentication, and not just those select databases.
lohjintiam Mon, 01/11/2010 - 19:55
FYI
wfm833ig.pdf somehow left out this information (Configurating NT Authentication for Unified CC). It's available in wfm82ig.pdf (page 43-48)
Sergey Popov Thu, 06/16/2011 - 06:12
Hello
I have UCCX 8.0.How can I do this steps? I don't found information about configuring users for linux based CCX databases.
