vpn basic
Jan 8th, 2010
HI Friends,
I have some under stnading about firewalls but very basic with VPN technologies and terminolgies. I need a kind help from your side. I have to create a Site-to-Site VPN over internet (IPSec VPN). I have to fill the below form and send to the other site, other site is a Telco they are requesting the below details from my side. My side i have a firewall on which i will create the VPN, and the Firewall connects to one ISP with a Public IP on the outside interface. I should mention the VPN Interface IP some where, that much I know, but -
what would be the Peer / Gateway IP address?
waht would be the Source/Remote IP address?
regards
Sunny
þ Gateway To Gateway
Peer/Gateway IP Addresses:
Source/remote  IP Addresses:
pompeychimes Sat, 01/09/2010 - 02:28
  • Bronze, 100 points or more
The peer/gateway IP addresses is likely the public IP address assigned to your Firewalls Internet facing Interface. The source/remote IP addresses are likely the LAN IP addresses (Encryption domain) from which you'll be originating traffic
Typically there are more paramaters to agree upon. Is this all you've been asked for?
James
