Cisco 2500 series router always gone into Router(boot)>
Jan 8th, 2010
Cisco  2500 series router always gone into Router(boot)> .. Even if i change the config register value it is always gone to Router(boot)>
Can u suggest what i supposed to do?
Peter Paluch Sat, 01/09/2010 - 00:49
Your 2500 routers is booting into so-called BootROM mode. I see three possible reasons for that: either the FLASH contents are erased or corrupt, or the configuration register value is wrong, or the configuration file in NVRAM instructs the router to boot into the BootROM or to an inexistent image.
Let's try this: Enter the ROMMON mode, i.e., after you power-on your router, wait a couple of seconds, then press the sequence. You will be presented with a prompt containing the single > sign. Now, type these two command:
o/r 0x2142
The first command will set the configuration register to the value 0x2142, i.e. ignore the stored configuration and load the first image in FLASH. The second command instructs the router to reset.
If even after this sequence of steps router still boots into BootROM mode, it is probable that the FLASH has been erased or corrupted. Try to verify its contents using the show flash command in the BootROM mode and try to download the proper IOS back. Are you familiar with that procedure?
Best regards,
