Help in Routing part of Cisco 3825
Jan 9th, 2010
Hello Guys,
I need help in configuring Cisco 3825 cisco router, Customer want to access this router from my SSL VPN means once they connected to SSL VPN they should be abel to do telnet to cisco device , so what routing i need to do in Cisco device?
Please advise.
Giuseppe Larosa Sat, 01/09/2010 - 02:08
  • Hall of Fame,
    Founding Member
Hello Gaurav,
is the VPN SSL going  to be terminated on the C3825 on in another device like an ASA?
for VPN SSL on C3825 you can read the config chapter from 12.4T security
http://www.cisco.com/en/US/docs/ios/sec_secure_connectivity/configuration/guide/sec_ssl_vpn_ps6441_TSD_Products_Configuration_Guide_Chapter.html
take in account possible licensing aspects:
Licensing
Starting from Cisco IOS Release 15.0(1)M, the SSL VPN gateway is a seat-counted licensing feature on the Cisco 880, Cisco 890, Cisco 1900, Cisco 2900, and Cisco 3900 platforms. A license count is associated with each counted license and the count indicates the instances of the feature available for use in the system. In the case of SSL VPN, a seat refers to the maximum number of sessions allowed at a time.
You can get the license at http://www.cisco.com/go/license.
see also the section
Configuring the SSL VPN Gateway to Distribute CSD and Cisco AnyConnect VPN Client Package Files
Hope to help
Giuseppe
Related Content
