unity connection 7.x error message connecting with cobra export
Jan 9th, 2010
Unity connection 7.x
cobra tool export
unable to connect to unity connection 7 database using cobra tool export.
-informix has been installed
-user right for remote has beendeclared
-proxy database is started
when we trying to connect to unity connection with cobra we have the folloing error message :
Error in load routineError opening event source registry key - access is denied - 2147024891
boub91 Sat, 01/09/2010 - 09:07
Hi Rob,
Thank you for your reply I will check this issue.
boub91 Tue, 01/12/2010 - 04:27
I tried with windows XP and it's working fine.
Thank you
