01-09-2010 04:56 AM - edited 03-04-2019 07:10 AM
I was testing mutual redistribution between EIGRP and OSPF, under eigrp process without
"default-metric" statement, mutual redistribution doesnt work.
router eigrp 1
redistribute ospf 4
network 192.168.1.20 0.0.0.3
default-metric 100000 1000 255 1 1500
no auto-summary
router ospf 4
log-adjacency-changes
redistribute eigrp 1 subnets
network 10.10.10.1 0.0.0.0 area 0
Is "default-metric" statement a must.
Solved! Go to Solution.
01-09-2010 05:22 AM
Hello Saquib,
your understanding is correct for EIGRP to be able to import routes from another dynamic routing protocol a seed metric has to be set with default metric command.
This is actually one of first checks in troubleshooting redistribution into EIGRP.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094613.shtml#rdc
the reason is that EIGRP composite metric cannot be compared to the metric of the source protocol, the seed metric provides values for bandwidth, delay and other parameters.
OSPF is a special case it has default seed metrics.
Hope to help
Giuseppe
01-09-2010 05:22 AM
Hello Saquib,
Hope to help
Giuseppe
01-09-2010 07:01 AM
why the seed metric is needed whenever you redistribute between any protocol to Eigrp or Rip?
Those protocols requires a (seed metric), it can be configured manually or through the (default-metric) command. The reason behind this is because those protocol doesnt recognize (metric 0).
As whenever a route is redistributed without a seed metric, a metric of 0 by default is a ssigned to those routes and is therfore is not taken by RIP or EIGRP cause they both dont recognize metric 0. However , In (ISIS) routing protocol, you dont have to a ssign a metric or a seed metric whenever you redistibute into ISIS as it recognizes metric 0.
Mohamed
01-09-2010 11:52 AM
Thanks Mohammed.
