conmurph Sun, 01/10/2010 - 16:32
  • Cisco Employee,
Hi Leandro,
Do you need to know what Linux releases work with WCS? If so, here is the link to the release notes and the operating systems supported.
http://www.cisco.com/en/US/docs/wireless/wcs/release/notes/WCS_RN6_0_170.html#wp44427
The following operating systems are supported:
Windows 2003/SP2 and Windows 2003 R2/SP2 32-bit installations with all critical and security Windows updates installed.
Windows 2003/SP2 64-bit installations are not supported. A 32-bit operating system running on a 64-bit capable hardware is supported.
Windows 2003 32-bit installations provide support for up to 64 GB of RAM provided Physical Address Extension (PAE) is enabled. Refer to Windows documentation for instructions on enabling this mode.
Red Hat Linux Enterprise Server 5.X 32-bit operating system installations.
Red Hat Linux Enterprise Server 5.X 64-bit operating system installations are not supported. A 32-bit operating system running on a 64-bit capable hardware is supported.
Windows 2003 and Redhat Linux version support on VmWare ESX 3.0.1 version and above.
Individual operating systems running WCS in VmWare must follow the specifications for the size of WCS you intend to use.
Cheers,
Conor
Leandro Nunes Wed, 01/13/2010 - 15:40
Actually I would like to know in which platform Location works and no WCS.
In  any way I thank for the attention and response.
Regards.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
