ASA blocking IPsec to any outside end-point
Jan 9th, 2010
I have a routed firewall configuration that requires folks on Inside network to be able to use
IPsec VPN which terminates both at the shared public interface and also other end points.
I can't seem to set the ASA to allow it.  I've added a low security IPsec-passthrough-map
which didn't help.
I am fine with globally allowing the use of IPsec from the internal network.
Any ideas would be appreciated.
Thanks,  Roger
vilaxmi Sat, 01/09/2010 - 11:52
  • Cisco Employee,
Is your tunnel UP and you are just not able to pass traffic or your tunnel itself is notcoming UP ? Try pasting show crypto isakmp sa and show crypto ipsec sa and also show run
For exempting vpn traffic form ACL check you can try :
sysopt connection permit-vpn global config command
Vijaya
