VPN Client locks up computet
Jan 9th, 2010
When going online with vpn, my computer locks up 5-10
minutes after connection.  The only way to reboot is a hard shutdown.  I am runnin XP SP3 and any help you can provide would be appreciated
emmanma77 Tue, 01/12/2010 - 20:54
Only suggestion is to check for your firewall software that may conflict / go in block mode when connected.. otherwise you're looking at a reinstall of the vpn client
Save any custom VPN profiles - located in C:\Program Files\Cisco Systems\VPN Client\profiles
Uninstall Cisco VPN client,
Delete Cisco VPN folder in  C:\Program Files\Cisco Systems - or rename the folder if you want to save it
reboot PC
reinstall Cisco VPN client ( or get more recent version than the one you are running, )
reboot PC <<-- important
attempt to connect again
