SPA3102 and FreeSWITCH VOIP to PSTN problem
Jan 9th, 2010
I am having trouble getting outbound calls to work, the call begins with a fair amount of feedback, is fuzzy and the volume is so low you cant really hear anything? The device is located in NA and it receives PSTN calls perfectly and forwards those on to the freeswitch server, its just outbuond calls that are a problem.
Line 1 is disabled, I am just using the FXO port. Attatched is my config.
Any ideas what to check?
Thanks!
