Routing between 2 Multiple Context
Jan 9th, 2010
Cisco ASA5520
Created two different context - Context A and Context B
Objective:- I would like to route between this 2 context INTERNALLY.
Is this achievable? Ive read from the cisco doc examples, most of it illustrates routing outside to the internet before coming back in to the other context.
I have a customer requirement whereby users on Context A would need to access some servers from Context B, that is, without routing out to the internet.
Please advise
Jon Marshall Sun, 01/10/2010 - 01:42
J_Vansen_S wrote:
Cisco ASA5520
Please advise
Well you shouldn't have to go out to the Internet altho it does depend on your topology setup.  There are 2 ways to do this -
1) traffic from A is routed out of context A and then routed to context B and vice-versa. So the 2 contexts are completely separate and you just need to make sure that there is a routed path between A and B. This in theory i guess could be the next-hop towards the internet.
2) each context has an interface connected to subnet which the servers are on. So you don't need to route out of A and back into B, you can simply go straight from A to the server subnet.
Which one to use is a matter of security requirements. But one thing i would recommend is that traffic to servers from A -> B should not go via the internet.
Jon
J_Vansen_S Sun, 01/10/2010 - 17:57
No there isnt any sharede interface on my setup.
Is the concept of shared interface the way to go to meet my objectives?
Jon Marshall Sun, 01/10/2010 - 18:15
As i said, it depends on your security requirements. If you are happy to have both contexts having direct access to the server LAN then yes a shared interface is one way to do it.
Jon
J_Vansen_S Sun, 01/10/2010 - 22:39
Thanks for the advice.
I have altered my design slightly to cater for shared interface.
The users on both context can now access to the server zone. Thanks!!
However, i am having a slight problem.
On the other hand, my servers could not access to the user zone instead?
I believe i have put in the necessary routes.
PLease advise
J_Vansen_S Sun, 01/10/2010 - 22:43
Attached is my update diagram.
Please advise
Apparently i cant access from the servers zone to zone1
But vice versa is working fine
trustcisco Mon, 01/11/2010 - 01:09
I have a similar network that i am designing now and i can really use your help.
First of all, what is the gateway of your servers located in 192.168.1.x ? Do they have internet feed ?
Do you use nat exemption for internal traffic ? for example from traffic flowing from zone_users to servers and vice versa or do you nat them ?
What if you need to provide access from zone 1 to zone users, what will you do then ?
I am posting my config here just to tell me if it is correct or not :
Asa 5510
System
iinterface e0/0
no shut
interface e0/1
no shut
no ip address
interface e0/1.1
vlan 2
interface e0/1.2
vlan3
interface e0/2
no shut
interface e0/3
no shut
no ip address
interface e0/3.1
vlan 4
context1
interface e0/0
ip address x.x.x.x
nameif outside
sec-level 0
interface e0/1.1
description users_lan
ip address 1.1.1.1 255.255.255.0
nameif inside1
sec-level 100
vlan 2
interface e0/1.2
description shared_services
ip address 2.2.2.1 255.255.255.0
nameif inside2
sec-level 90
vlan 3
route outside 0 0 router1_inside_if
context2
interface e0/2
ip address x.x.x.x
nameif outside
sec-level0
interface e0/3.1
ip address 3.3.3.1  255.255.255.0
nameif inside1
sec-level 100
vlan 4
interface e0/1.2
ip address 2.2.2.2 255.255.255.0
nameif inside2
sec-level 90
vlan 3
route outside 0 0 router2_inside_if
Thanks.
J_Vansen_S Mon, 01/11/2010 - 01:34
Apparently i point my servers to the gateway on Context B for internet feed.
I did not use nat exemption for traffic flowing from zone_users to servers.
Instead i use dynamic pat
global (shared) 1 interface
global (zone_users) 1 interface
nat (zone_users) 1 192.168.7.0 255.255.255.0
trustcisco Mon, 01/11/2010 - 01:46
Yes you are right i missed the L3 on your diagram, i am asking you this cause my network is exactly like yours with the diferrence that mine fully L2.
That's why i am asking you for the gateway, any ideas for my case ?
trustcisco Mon, 01/11/2010 - 02:13
Why you have to use dynamic pat instead of nat exemption with access lists and a static route for your L3 network ?
Jon Marshall Mon, 01/11/2010 - 03:37
Are you still having a problem with your setup or is it fixed ?
Jon
