CME/CUE - sip trunk, no dtmf
dbauman_wan
Greetings,
When placing calls to a CUE AA over a SIP Trunk (from a Broadworks platform), dtmf doesn't make it through.
I've played around with the dial-peer settings, but have had no luck.
dtmf-relay sip-notify
dtmf-interworking rtp-nte
b2bua
Is there anything else I should be looking at?
David
Here you go:
voice-card 1
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sccp local GigabitEthernet0/0
sccp ccm 9.13.29.30 identifier 1 version 4.0 -- Use your own IP address
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register XCODE123456 (The name of the gateway)
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
codec g729br8
maximum sessions 10
associate application SCCP
telephony-service
max-ephones 1
max-dn 1
ip source-address 9.13.29.30 port 2000 --> Use your own IP address
sdspfarm units 1
sdspfarm transcode sessions 10
sdspfarm tag 1 XCODE123456
MK
12 Replies 12
mightyking
Level 6
Level 6
Try
Gateway# voice service voip
Gateway# allow sip-to-sip
You may need to transcode the stream between sip trunk and CUE
Codece used by CUE is G.711.
MK
sip to sip and all options are there.
I am using g711ulaw on the sip trunk.  Can you send information about the transcoding?
David
Here you go:
voice-card 1
voice service voip
sccp
sccp ccm group 1
keepalive retries 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
codec g729br8
maximum sessions 10
telephony-service
max-ephones 1
max-dn 1
sdspfarm units 1
MK
When I try to put this config under telephone-service (sdspfarm tag 1 XCODE123456), I get this error:
Can't change name for registered mtp
You need to use the name that you have given to your gateway. XCODE123456 is just an example.
MK
"gateway" being my sip trunk provider in sip-ua?
You need to use the name of the router where the DSP's are located. In your case, it would be the name of the CME.
MK
Thats what I originally thought, but was still giving me the same error.
What error message do you get?
MK
"Can't change name for registered mtp"
Instead of " XCODE123456" in the above example, use the name that you have given to MTP and reset the SCCP by doing the following:
Gateway# no sccp
Gateway# sccp
MK
I never gave it XCODE123456, but will definately try and removing sccp and re-adding it.
Thanks!
David
