Giuseppe Larosa Sun, 01/10/2010 - 05:06
  • Hall of Fame,
    Founding Member
you need to use set based commands:
set password
set enablepass
see catos config guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/8.3and8.4glx/configuration/guide/configur.html
start by reading
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/8.3and8.4glx/configuration/guide/cli.html
I don't remember that enable secret is supported
all this under the hyphotesis you know current enable password and the way to login to the box
otherwise you need to use a password recovery procedure
Hope to help
Giuseppe
