Auto Attendant (uc500)
Jan 10th, 2010
hello guys
i have configured autoattendent on uc500.internally when i call on AA extension it works fine and transfering calls etc. but when i called on AA pstn no. it didn't work.we can hear the welcome prompt but when pressing 0 or 1 it did nothing. here is the debug info.i am using a sip trunk and from my provider side there is no issue.they told me. i got with voip ccapi inout.
Plz help on this issue
000570: Jan 10 11:35:56.163: //31/229439A1803E/CCAPI/cc_api_caps_ack:
   Destination Interface=0x8720D350, Destination Call Id=30, Source CallAPI/cc_a
pi_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x1F
000582: Jan 10 11:36:10.355: //30/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3w
ay_conference:
   Check DTMF relay digit begin for 3way conf
000583: Jan 10 11:36:10.355: //30/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
000584: Jan 10 11:36:10.355: //30/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way
_conference:
   Check DTMF relay digit end for 3way conf
000585: Jan 10 11:36:26.551: //30/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
000586: Jan 10 11:36:26.551: //30/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3w
ay_conference:
Adam Thompson Tue, 01/12/2010 - 08:46
  • Silver, 250 points or more
The dial-peer that is sending your inbound calls to the AA, do you have the dtmf-relay rtp-nte command specified? You could also try the dtmf-relay sip-notify command.
An example dial-peer would be:
dial-peer voice 2001 voip
description ** auto attendant number **
destination-pattern 498
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
Adam
Please rate if helpful
