How we can login automatically into the ip phone, immediately after logging on to our laptops/pc's
sayeedibrahim
We are using Unified Comm. Manager 7.0
We have extension mobility working perfectly fine but i have been asked to check how we can login automatically into the ip phone, immediately after logging on to our laptops/pc's
Appreciate the support
Adrian Saavedra
Level 7
Level 7
Hi friend,
This could help you.
http://www.rsconnect.net/
Hope to help, please rate if it does.
Best regards,
-- Adrián.
Adrian Saavedra
Level 7
Level 7
Hi friend,
Best regards,
-- Adrián.
Hi Friend
Thanks for the link.
It should solve my problem.
Cheers
