ASDM webpage not open
Jan 10th, 2010
hi all,
        i have one prob regarding ASA ASDM , when i open the asdm web page the following error ocuured pls suggest ,
mak
Dileep Sivadas ... Sun, 01/10/2010 - 23:07
Can you please change the security zone setting for ASA IP.
Add this IP in intranet zone and try.
solpandor Mon, 01/11/2010 - 03:50
hi
check your Java version - i think there are issues on JRE1.6  - try JRE 1.4
Also, try changing the Privilege Level to 15 for the user (unless of course they need to have it set to 2)
