Same Security levels on multiple interfaces
Answered Question
Why should one keep same security levels on multiple interfaces on Cisco Firewalls? What could be the impact? I was under the impression that same security level cannot be given on multiple interfaces, but i came across a configuration,and had to change my assumption. Just want to understand the best practice and the impact if we configure the interfaces in such a way that 2 interfaces have sec-level 60, 2 have sec-level 80 with remaining as inside and outside...
Correct Answer by Dileep Sivadas ... about 7 years 1 month ago
If you assign same security level for multiple interface , there will no traffic flow by default unless you configure same-security-traffic permit inter-interface command.
This is used to completely isolate traffic from two interfaces.
Dileep
Overall Rating: 5 (1 ratings)
Correct Answer
Dileep Sivadas ... Mon, 01/11/2010 - 01:58
Dileep
