Is Outlook Web Access 2007 supported through IOS SSL VPN?
Jan 11th, 2010
Hello all,
I recently migrated my Exchange Server from 2003 to Exchange Server 2007.  I had a URL for Outlook Web Access 2003 which worked fine but now that I have updated it for Exchange 2007 it seems to time out without ever loading the page.
I have an 1801 router running IOS 12.4(15)T10 and the SSL VPN works fine otherwise.
Any suggestions would be gratefully appreciated.
Shane
richadobo Fri, 01/29/2010 - 03:37
Having similar issues using Exchange 2007 on Small Business Server 2008 and also with Microsoft Dynamics CRM on Win Server 2008.
We're using a Cisco 1841 HSEC.
Sharepoint and other sites hosted on the servers work fine. Just OWA and CRM that are causing issues.
Any help greatly appreciated,
Cheers!
Rich.
l.tating Mon, 02/22/2010 - 18:18
I have quite similar problem with IOS SSL VPN (WebVPN). This time with login to ACS. This is my simplified diagram:
(ACS)----------------R1------------------R3-------------------- (client)
I can enter the ACS's URL and see the login page. but when i enter my username/password there is error displayed on ACS login page "Login failed. Protocol Error"
I checked on ACS to see if any logs register but none. It seems that my login packets do not reach ACS.
I tried to run webvpn debugs on R1 and entered login credentials, the result was IOS crash. =(
Lorenz
Related Content
